It is currently Fri Aug 08, 2025 2:00 pm
PostPosted: Tue Aug 11, 2009 11:00 pm
I picked up a Takamine 12 string through a trade and the action is prettyh high, and not a lot of saddle to work with. Thinking I might have to remove the neck and reset. Wondering if anyone has experience with Takamine. It is not a bolted neck so assuming it is a dovetail. Any advice?
PostPosted: Wed Aug 12, 2009 3:42 am
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
what i done to figure out if its a dovetail or dowel is
i made what should be called a dovetail detector
I loosened the fretboard extension and got a really thin bit of metal around 0.5 thick x 1/2" wide
i bent a wee catch on the end and grinded a taper to one side so i could get the catch in and out of
the dovetail pocket
it worked for me altough i have only used it twice
and it did a get a bit mangled aswell
As myself being a novice im saying listen to what someone else says about this first
this method could be risky because its a tight fit to get your detector in there
it does scratch the top under the extension and could possibly damage your f/b
but it saves pullin a fret and drillin holes if you dont need to
im sure someone else does this method ...mabye frank ford or someone
hope this helps tomas
PostPosted: Wed Aug 12, 2009 5:36 am
.5 is a half inch do you mean 5 thousandths
PostPosted: Wed Aug 12, 2009 6:23 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I haven't mess with any Tak's other than minor stuff, but I was told the ones made in Japan had Dovetails, and the ones made other places had dowel. Again, this is just hearsay.
PostPosted: Wed Aug 12, 2009 7:07 am
If you have any friends that are X Ray techs or docs sneak your guitar in and X Ray the joint. That will tell you exactly what is going on.
TJK
PostPosted: Wed Aug 12, 2009 9:38 am
I seem to recall that those are epoxied dovetails. Sorry.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Wed Aug 12, 2009 9:24 pm
Thanks all for your input. I was reasearching Takamine and discovered thy are owned or serviced by Kaman who makes Ovation. Hope Im right - I have a friend who has a friend at Kaman in CT and he is going to check and see if they might make an exception and cover under warranty. The guitar is only a year old and warranty is limited to original owner. The guy I got it from received it as a gift and didnt have any paperwork. Will see how it goes.
I was considering the J Doctor device that bolts to the bridge and if I recall it lifts the belly some. It looks like the pressure from the string tension has bellied the top behind the bridge so the front of the bridge is down - not collapsed by any stretch but enough that I think this is what is going on. I can see the rise behind the bridge.
PostPosted: Thu Aug 13, 2009 5:13 am
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
I recently had to reglue one of the x-braces on a Jasmine (made by Takamine), the upper part of the brace by the waist was loose and caused the top to belly in front of the bridge, but the action on that one was lowered. Check out all the braces, maybe the braces behind the bridge are loose. Just a thought.
Users browsing this forum: CarlD and 40 guests
